FOC import not working
Was thanked: 81 time(s) in 76 post(s)
The URL is
N5XZ on 1/27/2021(UTC)
Thanks, that worked.
WN4AZY on 1/27/2021(UTC)
K8ZM on 6/17/2026(UTC)
WN4AZY on 6/22/2026(UTC)
#7 Posted : Tuesday, June 23, 2026 7:03:42 PM(UTC)
It is there.
What I would like to do is have LOGic download from the site without having to manually download the file. You can edit the URL.
Let us know. Tnx.
#8 Posted : Thursday, July 2, 2026 6:11:31 PM(UTC)
Dennis, the new file is located at https://g4foc.org/wp-con.../tylerdata/All_Time.txt . Of course, one must be an FOC member to access it. As you can see it is a text file, not zip. The program is looking to unzip a file, so it won't work. If I can find a zip file online, I'll let you know.
FOC_All_Time.txt (104kb) downloaded 3 time(s).
#9 Posted : Saturday, July 4, 2026 11:16:49 AM(UTC)
Was thanked: 152 time(s) in 135 post(s)
will it work if you zip it?
Doug W5GA
#10 Posted : Saturday, July 4, 2026 3:25:19 PM(UTC)
Doug W5GA
I haven't tried it yet.
#11 Posted : Sunday, July 5, 2026 2:34:13 PM(UTC)
Doug W5GA
I tried but I run into multiple errors.
Dennis?
