FOC import not working
Was thanked: 78 time(s) in 73 post(s)
The URL is
N5XZ on 1/27/2021(UTC)
Thanks, that worked.
WN4AZY on 1/27/2021(UTC)
K8ZM on 6/17/2026(UTC)
