Groups: Registered, Beta Testers Posts: 466 Location: Richmond, TX
Thanks: 41 times Was thanked: 78 time(s) in 73 post(s)
The FOC numbers import utility is not working. Has the URL changed? 73, Allen N5XZ
Groups: Administrators, Beta Testers Posts: 3,216  Location: Auburn, GA Thanks: 1107 times Was thanked: 537 time(s) in 449 post(s)
Hi-- It is working fine here on 9.21.2. The URL is http://wa.g4foc.org/LoggerFiles.zip
Click the Edit URL checkmark, then DEFAULT. Let me know. Tnx & 73, Dennis WN4AZY
Thanks, that worked. 73, Allen N5XZ
LOGic imports FOCCallHistory.txt from LoggerFiles.zip. The ZIP file isn't saved anywhere. It is all processed in memory. It looks like http://wa.g4foc.org/LoggerFiles.zip
I am a member (1953). I will try it when released. 73, Allen N5XZ
