v10.00.33 Update Install SlimDX Runtime Error
#1 Posted : Tuesday, June 16, 2026 10:13:53 AM(UTC)
Hi Dennis, hope you all are well !!
Installed latest v10.00.33 and got a SlimDx Runtime error. I just ran it and all seems fine. Just an FYI...
Issue-20260616-SlimDX RuntimeError.png (9kb) downloaded 36 time(s).
WN4AZY on 6/16/2026(UTC)
#2 Posted : Tuesday, June 16, 2026 1:47:52 PM(UTC)
Ok, since it was an update, it is probably still OK. If the LOGic's voice player fails, you can try to install it manually. Just download the attached file and double-click it. Or, just go ahead and install it regardless. Choose the REPAIR option.
SlimDX Runtime .NET 4.0 x86 (January 2012).msi (5,384kb) downloaded 0 time(s).
#3 Posted : Wednesday, June 17, 2026 9:22:09 AM(UTC)
I tried to download from the link and it says its not there or has been moved.
I seem to remember doing this in the past. Though I kept a copy of SlimDX (Jan2012) but apparently not.
Sorry,
UPDATE: Just found a copy of the SlimDX installer. Did the repair and re-installed LOGic and no issues !!
Thanks Again,
WN4AZY on 6/22/2026(UTC)
