Report Builder Error
#1 Posted : Tuesday, March 24, 2026 12:15:03 PM(UTC)
Tried running a couple QSL card reports to modify and am getting a Report Builder Error for margin box whenever I click on the Page Setup icon. See attached. Never had these issues before.
Running latest LOGic v10.032.
Thanks for any help.
Issue-20260324-Report Builder Error.png (11kb) downloaded 21 time(s).
Issue-20260324-Report Builder Error1.png (73kb) downloaded 17 time(s).
#2 Posted : Monday, March 30, 2026 2:17:19 PM(UTC)
Hi Brad--
Please zip up the report in question (there is a .REP and .FPT part) and attach to a message. I will take a look!
K8ZM on 3/30/2026(UTC)
#3 Posted : Monday, March 30, 2026 4:23:11 PM(UTC)
Here is one of them (note that the report title says 3.5 x 5.5 but its actually 3.5 x 5). This used to work a couple months ago but it seems I have 3 of these now that do the same thing when you click on Page Set Up. Its also weird that the header and footer bands are 11" or so wide when the card is only 5" wide.
I have other questions/issues on FoxyPreviewer but will start a new thread.
Thanks for taking a look. Wish I could fix this myself but sadly am Foxpro "limited"! I did start to re-create a new report for this by renaming a "legacy" one that works and then copy/pasting the layout but CQ WPX Contest took priority this weekend. By the way LOGic worked just fine for contesting (as usual) !!
K8zm- QSL Card 3.5x5.5.zip (11kb) downloaded 11 time(s).
WN4AZY on 4/7/2026(UTC)
#4 Posted : Sunday, April 12, 2026 9:02:03 PM(UTC)
Sorry for the delay on this.
When I went to open the report to modify it, it prompted for several image files. I just selected the ARRL Logo.
The report opened, and no error getting to the Page Setup.
Are you getting the error with every report?
k8zm Screenshot 2026-04-12 215736.png (102kb) downloaded 7 time(s).
K8ZM on 4/12/2026(UTC)
#6 Posted : Sunday, April 12, 2026 10:51:32 PM(UTC)
No problem.
Not every report. This one and at least 2 other QSL Cards. I haven't run into this problem on other reports but then again Its rare I need to modify or customize anymore as all my modified/customized reports I did several years ago.
I'll try to modify a bunch and see if the Page Setup issue shows up, if so I'll report back and attach the ones that matter, otherwise I'll just finish re-creating this one and the other 2.
Thanks for looking !
#5 Posted : Tuesday, April 14, 2026 11:30:27 AM(UTC)
Just curious but why is the Page Header and Page Footer band 11" wide ? The card is only 5. I just finished re-creating this one and both those bands are the same width as the card.
WN4AZY on 4/27/2026(UTC)
