Filter spot log by mode
#1 Posted : Saturday, April 11, 2026 12:17:36 PM(UTC)
Was thanked: 73 time(s) in 68 post(s)
I would like to see an added option to filter the spot log by mode. Is it possible to add this feature?
#2 Posted : Saturday, April 11, 2026 12:30:38 PM(UTC)
Was thanked: 224 time(s) in 201 post(s)
Hi Allen, hope you are well !!
It has it unless you need something different. In the Spot Log under the Spots tab there is a funnel icon, click the funnel and you can quickly filter on almost anything, click the red x to clear it. Additionally in the Spot Log go to options and you can create a pre-filter, look for the band and mode setup icons. Using the pre-filter will filter the entire log and you'll have to go back an select the No Prefilter check box to return to no pre-filtering.
Maybe one of those two will give you what you need,
73 de Brad K8ZM
Guest (10)
