Posts: 448 Location: Missouri
Thanks: 91 times Was thanked: 145 time(s) in 130 post(s)
Dennis, I just noticed this last night. Having winkeyer window open and active, and then resetting the radio interface via the main log screen reset button causes the winkeyer window to close. should it do that? 73 Doug W5GA
Groups: Administrators, Beta Testers Posts: 3,181  Location: Auburn, GA Thanks: 1076 times Was thanked: 523 time(s) in 437 post(s)
I'll look at the code. The idea is to close all COM ports and reopen them. Probably the description should say Reset Radio, Rotor and Winkeyer....
Stay tuned.
I checked the code. It is indeed designed to close and reopen anything using a serial port. I fixed the description on the menu.
Thanks for bringing this to my attention.
OK, I get that the intent is just to reset the com port, but shouldn't it re-open the winkeyer window, also? It's not doing that. 73 Doug W5GA
Groups: Registered, Beta Testers Posts: 447 Location: Richmond, TX
Thanks: 40 times Was thanked: 68 time(s) in 63 post(s)
Originally Posted by: W5GA  OK, I get that the intent is just to reset the com port, but shouldn't it re-open the winkeyer window, also? It's not doing that.
I would like to see it do that also. 73, Allen N5XZ
