Logic not reading frequency and Rotor not working with Flex 6600 radio
KV3R
#1 Posted : Wednesday, September 17, 2025 4:38:51 PM(UTC)
Was thanked: 2 time(s) in 1 post(s)
I had a direct lighting strike in June. I controlled the station remotely. I replaced the Icom 7300 with a Flex 6600. WSJT reads the frequency from the radio. I can not get Logic to read the frequency or control the rotor. The rotor is on Com 1 and it worked with Logic and N1MM before the lighting strike.The rotor is not working with N1MM. I replaced the Rotor EZ board in the control box.
I am running the latest Logic update.
I am now questioning myself! Did I plug the Serial cable into the computer? I'm not at the station to check.
If someone could help me get Logic to read the radio and log my WSJT contacts that would be great. I could live with out the rotor until I get to the station to see if I did or did not connect the serial cable from the rotor control box. Can you tell that I have a lot on my plate. Dealing with insurance will stress you out.
73, and Thank you
Bill KV3r
This page was generated in 0.015 seconds.
