v10.00.31 Unexxpected error on Send
#1 Posted : Tuesday, August 5, 2025 6:39:22 PM(UTC)
Was thanked: 231 time(s) in 208 post(s)
Tried to install v10.00.31 and got error "The underlying connection was closed: An unexpected error occurred on a send. The handshake failed due to an unexpected packet format". Snippet attached of the "Install LOGic Update" window.
Thought these types of errors only occurred on Mondays (hihi) !!
v10.00.31 Unexpected Error on Send.png (63kb) downloaded 154 time(s).
#2 Posted : Tuesday, August 5, 2025 8:53:12 PM(UTC)
Strange, it is fine here.
Please try this direct link:
http://distribution.hose...LOGicUpdate_10.0.31.exe
K8ZM on 8/6/2025(UTC)
#3 Posted : Tuesday, August 5, 2025 10:53:34 PM(UTC)
Ok, so more problems.
Tried the direct link and windows defender stopped it from downloading. I over-rode it and let it install, when the install got to SlimDX Runtime it threw an alert that a program run as part of the setup didnt finish as expected (see attached).
LOGic did launch but I didnt get the usual installing the prefix table listing in blue text at the top left of LOGics desktop, just the sentence "installing the prefix table" for about a second then LOGic continued launching. I'll fool around a little in this version but dont want to do too much and will revert back to 10.00.30.
Never had these kind of errors before....
PS: v10.00.31 is freezing up, so tried to revert back to v10.00.30 using LOGics installer and got the same installer error as v10.00.31. I keep copies of updates so tried to install LogicUpdate_v10.00.30 and got the same SlimDX Runtime issue. LOGic launched but also freezing up so am stuck in the water at this point.
PSS: Tried to re-install LogicUpdate_10.00.30 again and still got the SlimDX Runtime issue. LOGic seemed to install and launch and not seeing any freezing or other issues yet. So except for the SlimDX Runtime issue it seems ok for the moment. Can you link me to the SlimDX Runtime executable and maybe I can install or replace this one and resolve that issue. The installer still shows the same "Unexpected Error on Send" even when trying to install v10.00.30.
v10.00.31 SlimDX Runtime Error.png (24kb) downloaded 146 time(s).
#4 Posted : Wednesday, August 6, 2025 1:26:57 AM(UTC)
Having reverted back to v10.00.30, I found SlimDX Runtime.NET 4.0 x86 (January 2012).msi in LOGics public folder and ran a "Repair". Re-launched LOGic v10.00.30 and all seemed fine....Pheew ! Then re-ran LOGicUpdate_10.0.31.exe previously downloaded from your link but disabled Defender this time just to be sure and all, including SlimDX Runtime installed fine. So am now working with latest update 10.00.31 and so far no screen freezing....WoooHooo!!
This leaves only the installer which still reports the "Unexpected Error on Send" (pic re-posted below)
v10.00.31 Unexpected Error on Send.png (63kb) downloaded 136 time(s).
WN4AZY on 8/6/2025(UTC)
#5 Posted : Wednesday, August 6, 2025 5:10:25 PM(UTC)
Hi Dennis, Hello Brad
this are my experience on 0.31 update.
After the warnings seems to run OK.
I will continue with the last 0.31.
Stay tuned for news.
#8 Posted : Wednesday, August 6, 2025 6:33:53 PM(UTC)
If you disable Windows Defender, wil the LOGic updater then work?
#6 Posted : Wednesday, August 6, 2025 6:37:17 PM(UTC)
Thanks for sending that. It doesn't seem to be related to any changes made to .31.... Will study it.
Does tools/database maintenance/reindex and pack work?
#9 Posted : Wednesday, August 6, 2025 9:32:04 PM(UTC)
Even with defender off I get the same "Unexpected Error on Send". I'm gonna try to update the updater client and see if that fixes anything, I'll PS this with the result.
Hi Mauro, hope you are well !!
PS: Updated the Updater and get the same "Unexpected Error on Send".
#7 Posted : Thursday, August 7, 2025 12:46:20 AM(UTC)
Yes, I reindexed right away and it worked fine. The only thing is that I had to re-enter the locator in the user information twice when I started Logic, which updated my QTH in the map. Otherwise, so far, I haven't noticed anything unusual.
Hi Brad, sorry for interjecting your message, but since it's about the update, I thought it was appropriate to give my 5 cents. As for my health, yes, I'm proceeding very carefully and have to be careful about injuring myself. These things increase personal stress, but I'm doing my best. Thanks for your thoughts.
Mauro CHU
K8ZM on 8/8/2025(UTC)
w7gtf
#10 Posted : Tuesday, August 12, 2025 3:31:22 PM(UTC)
Dennis, and all,
10.31 downloaded easily and flawlessly here. Windows 11/Dell Inspirion small desktop.
Regards,
Ron/W7GTF
#11 Posted : Wednesday, August 27, 2025 9:40:15 PM(UTC)
In the Updater, what exactly is happening when you click the "Install Version 10.0.31" button ?? Can you give me a list of what occurs first, second, etc ??
The instant I click on the "Install Version" button it immediately displays "The underlying connection was closed: An unexpected error occurred on a send. The handshake failed due to an unexpected packet format." This message comes up so fast I can't believe it. Once it shows it, it adds to the desktop the LogicUpdate_10.0.31.exe file even though I didnt check the "Retain the file after installation". Also if I try to close the Updater, it pops up a window saying a file download is in progress even though its not. I'm just trying to dive deeper into whats going on. Thanks for any help !!
v10.00.31 Unexpected Error on Send.png (67kb) downloaded 152 time(s).
#12 Posted : Thursday, August 28, 2025 9:38:14 AM(UTC)
The first thing that happens is that it downloads the update using HTTP pretty much like your browser. After the download completes, it runs the update. Then finally, after the installer exits, if RETAIN is not checkmarked, it deletes the download.
So it starts the download. It gets to the point of creating the empty file. The unhandled exception occurs and the program terminates before it can delete the file.
Check this out:
https://community.fabric...ected-error/td-p/3032659
#13 Posted : Thursday, August 28, 2025 1:40:35 PM(UTC)
Thanks Dennis !
So I reviewed the link and IPV6 and IPV4 protocols and all the test combinations passed from the link they provided. So, what is the server address its trying to connect to ?? Is it at http://hosenose.com or https://hosenose.com ?
I seem to think this may be yet another issue with my ISP, Spectrum, especially since they were blocking the Updater just recently, so I wonder if they missed something when they unblocked it. If all LOGic related server access is to a Hosenose.com server I will send them another unblock request for everything at that domain.
Good news is that AT&T is running Fiber in our neighborhood so in a couple weeks I may have a different ISP !!
Thanks for the help !
#14 Posted : Monday, October 6, 2025 5:18:03 PM(UTC)
RESOLVED with new WIN 11 PC and CLEAN Install of LOGic !!
WN4AZY on 10/14/2025(UTC)
