Cluster
WB2WJF
#1 Posted : Tuesday, June 24, 2025 12:30:29 PM(UTC)
I know the old Dx Summit is now defunct and I am trying to get Dxsummit.fi to work. No luck. I am not able to get any new cluster enabled so that I can receive spots. I can't find the screen to add a new cluster.
Any help wud be much appreciated.
Ross, WB2WJF
#2 Posted : Tuesday, June 24, 2025 8:53:09 PM(UTC)
Was thanked: 203 time(s) in 180 post(s)
Hi Ross, hope you are well !!
DX Summit works, its my default. For that or DXSCAPE navigate to the top left of LOGics desktop, click on Forms and select "WebCluster DX Summit" or "WebCluster DXSCAPE". If you want some other source select either Telnet 1 or Telnet 2 and input the data for the source your looking for. LOGics Help has a lot of useful information on this.
Let us know if you get it working !
73, de Brad K8ZM
WB2WJF
#3 Posted : Wednesday, June 25, 2025 8:09:04 AM(UTC)
Hi Brad, Thanks for your reply. DxSummit does work but it is very slow, and posts don't update as quickly as they did in the past. (I think I started with Logic 4 or 5 around the year 2000 but can't remember exactly.) I tried Telnet but the screen does not let me enter any data for web sites. I think the problems started with my last update as I now get error msgs. when I start Logic and the screen locks up frequently and requires a reload of the program. I will keep working on it.
By the way, on a different subject, my best friend and neighbor in Florida owned a business in Mentor. It was US Endoscopy. Sold to Steris Corp. in 2012.
Agn, thanks for your help and if you have other suggestions let me know.
Ross, WB2WJF
#5 Posted : Wednesday, June 25, 2025 11:32:04 AM(UTC)
Was thanked: 228 time(s) in 197 post(s)
Ross,
Try setting the Timer Interval to a lower number to speedup DX Summit spotting.
Did you select a host from the drop down box in the telnet window to connect?
73 Kyle
WB2WJF
#6 Posted : Wednesday, June 25, 2025 2:22:55 PM(UTC)
Hi Kyle, good to hear from you agn. The time was set to .9 for some reason. This morning I set it to 2 mins. I just set it to 1 min. I have tried clicking on to Host box to get the drop dowm menu of hosts but no host show. I tried both Telnet 1 and Telnet 2 and ther are no hosts to choose from. I have tried reloading Logic using the saved file from my last download. I am using V 10.0.28
The program is usable but it was much easier in the past.
thanks, Ross WB2WJF
#4 Posted : Wednesday, June 25, 2025 11:29:17 PM(UTC)
Ross, WB2WJF
I remember US Endoscopy and when Steris bought them. Steris grew considerably since then and occupy many buildings here in Mentor. There were 6 or so competitors that started up here but didn't last long, Steris is a tough nut to crack !! Hope your friend is enjoying life in FL!!
To add to what Kyle was saying I attached a pic of a Telnet window, maybe it will help. Not sure why you're not seeing the host list but you can add whatever you want by clicking on the SETUP icon in the Telent window....more visuals in the pic.
Let us know...
TF5B, Guest (4)
