10.0.4 POTA Award Tracking
N6DHZ
#1 Posted : Thursday, January 13, 2022 2:50:46 PM(UTC)
jshryne
I updated to 10.0.4 which now includes the POTA values for awards tracking. I had previously setup a user field for POTA and now I'm trying to figure out how to get the POTA field to show the drop down with the POTA values. I've searched the forum post but haven't hit the correct answer. So, any advise would be appreciated.
#2 Posted : Thursday, January 13, 2022 4:00:43 PM(UTC)
Click on Tools>Setup>Logging Fields, Spotting, Award Tracking
Select POTA and Enable and Save
Now from the LOG - MAIN screen click on the little man icon in the bottom right of screen to select User-defined fields.
Select the next (none)
Select POTA
Click Select
Click OK
From here you should have a drop down menu on your logging screen. ??
73 Kyle
WN4AZY on 1/14/2022(UTC)
N6DHZ
#3 Posted : Thursday, January 13, 2022 5:14:43 PM(UTC)
jshryne
Select POTA
Click Select
Click OK
73 Kyle
Kyle, thanks for the reply but I already have a user defined field for POTA that I added as you describe to the log form. I assumed after the update it would have a drop down lit like the IOTA field etc. I figure I'm still missing some setting to add that to the existing user defined field.
#4 Posted : Friday, January 14, 2022 9:15:19 AM(UTC)
Go to tools/setup/log fields. Retrieve the POTA field. Checkmark EDIT USING LISTS TABLE.
Thanks for your help with this. BTW, I did another import that includes the lat/lon and country code in the comment. Just install 10.0.4 again.
N6DHZ
#5 Posted : Friday, January 14, 2022 11:05:25 AM(UTC)
jshryne
I get an error as follows
"non-edited data already exists in the list table for POTA
List not permitted
If you want to create a list edit for this field, go to the list form and convert the POTA list to a regular list, or delete it and type in a new list."
Hacked around but couldn't find the where to convert it.
I'll install 10.0.4 again.
#6 Posted : Saturday, January 15, 2022 10:17:11 PM(UTC)
OK, sorry.
Go to tools/setup/log fields, navigate to POTA, then delete the POTA list. Reinstall 10.0.4 to reinstall the POTA list. Be sure to select the option to install new lists.
Now you can change EDIT USING LISTS TABLE.
K7PDW
#7 Posted : Thursday, May 8, 2025 6:26:48 PM(UTC)
DAVE
I cannot figure out how to enable POTA. I am running Ver 10.0.29
"Select POTA and Enable and Save" I find POTA in the "Log fields" window and click on it to highlight POTA but I cannot find where to Enable or Save. What am I doing wrong?
#8 Posted : Thursday, May 8, 2025 8:04:52 PM(UTC)
Dave, you're in the wrong spot. Go to tools/setup/log fields, do a search for pota. In the pop up box, you should see a place to check mark enable. Do that, and save. I've attached a pic of what you should be seeing.
WN4AZY on 5/13/2025(UTC), K7PDW on 5/27/2025(UTC)
This page was generated in 0.079 seconds.
