Informations
#1 Posted : Thursday, March 6, 2025 11:48:31 AM(UTC)
while transferring 280 qsos in adif format in my Logic I forgot to add the SRX field, that is the Grid exchanged in FT8 with the same value but with the field called SRX.
Unfortunately I realized it after updating the entire log and honestly I am missing that data that is then automatically put in the qsl.
My request is to know if it is possible to massively copy the data that are in the GRID field in the field called SRX and only in the qsos with date 2025-03-05.
What is the instruction to put in the Mass Change procedure so as not to manually update all the qsos?
Thanks Mauro IKØCHU
#2 Posted : Thursday, March 13, 2025 3:37:33 PM(UTC)
Sorry for the delay in my response.
Make a backup first!
Try this:
IN tools/databasee commands, type
USE LOG
replace userfields with updateuserfield("SRX", VAL(GRID)) for BETWEEN(QSO_DATE,{^2025-01-01},{^2025-03-31}) AND TYPE(GRID)="N"
replace grid with "" for BETWEEN(QSO_DATE,{^2025-01-01},{^2025-03-31}) AND TYPE(GRID)="N"
This will work if there are less than 256 total characters in USERFIELDS.
So try it.
If it doesn't work, you can always export that range of QSOs to ADIF, edit with notepad (mass change GRID: to SRX:), and reimport
Tnx for using LOGic.
