Buttons
N6FM
#1 Posted : Monday, July 2, 2012 10:29:33 PM(UTC)
A minor idea I have would be to make seldom used buttons (such as "setup" in the band map) smaller than the other buttons used more frequently (such as "set rig"). This would make it less likely to hit the wrong button in the heat of battle, so to speak..
#2 Posted : Sunday, November 11, 2012 8:11:35 PM(UTC)
Thanks for the suggestion. We generally try to make the buttons as small as practical to conserve real estate, while trying not to cram them too close together.
One thing we have started doing is having infrequently-used buttons or buttons that affect a neighboring control with no text -- just a little square. Hover test tells you what it does.
An example is the Set Default Printer button on the Run Report form.
Guest (5)
