Multiple Grid Squares per QSO
#1 Posted : Thursday, June 15, 2023 12:56:24 PM(UTC)
Was thanked: 209 time(s) in 186 post(s)
This feature was added several years ago but dont think it was ever finished. I had all the changes implemented long ago re-GRID, FFMA, Grid field Size, etc, etc. Here's what works and what doesnt;
Progress 2 for Grid and Progress List: works
Progress for FFMA (Main): Ignores all multi-grid QSO's
Awards Report for Grid: Ignores the 2nd grid for all multi-grid QSO's
Awards Report for FFMA: Ignores all multi-grid QSO's
Really would appreciate a fix for these, keeping track manually of multi-grid qso's continues to be more than a tedious task.
Trying to filter the log on the 1st grid in the field works but returns nothing if trying to filter on the second grid.
Thanks, Brad K8ZM
WN4AZY on 6/16/2023(UTC)
#2 Posted : Friday, June 16, 2023 7:46:11 AM(UTC)
Was thanked: 517 time(s) in 431 post(s)
Will do.
I think I did this already:
Will double-check.
Thanks!
#3 Posted : Saturday, June 17, 2023 9:55:00 AM(UTC)
Thanks !!
Also, when importing QSLs from LoTW, multi-grids/Qso are not importing. Attached is what I got today.
73 Brad, K8ZM
PS: I use GridTracker and am having a similar conversation with their developer. He goes by the ADIF standard which apparently says when there is a requirement to store two or four adjacent locators they must be in the field VUCC_GRIDS or MY_VUCC_GRIDS, also ONLY 4-character locators are allowed, i.e., EN90,EN91,EN92,EN93.
https://www.adif.org/314....htm#Maidenhead_Locator
My last LoTW QSL download in fact has the VUCC_GRIDS field populated if 2 or more locators, otherwise all single grid locators are in the field GRIDSQUARE.
WN4AZY on 6/18/2023(UTC)
#4 Posted : Sunday, June 18, 2023 10:48:47 PM(UTC)
Added this snippet showing a single multi-grid QSO I downloaded from LoTW (LOTW_Download_ADI) as it shows LoTW only populating VUCC_GRIDS when there is more than one locator and ignores GRIDSQUARE altogether.
The developer of GridTracker advised GridTracker reads VUCC_GRIDS when GRIDSQUARE is empty, I tested this and it works. If GRIDSQUARE contains multiple locators it ignores all but the first one, if both GRIDSQUARE and VUCC_GRIDS contain locators (which should never happen) it ignores VUCC_GRIDS and only reads the first locator in GRIDSQUARE. For me to use GT I export my LOGic log in ADIF format, then change GRIDSQUARE to VUCC_GRIDS for QSO's with multiple locators, then import into GridTracker. It works albiet a PITA.
GridTracker links with other loggers, HRD, N1MM, DXKeeper, HamZone, Log4OM, N3FJP. Maybe LOGic in the future BigGrin
WN4AZY on 6/19/2023(UTC)
#5 Posted : Friday, July 14, 2023 8:56:09 AM(UTC)
Additional FYI,
ClubLog also recognizes the adif field VUCC_GRIDS when multiple grids are confirmed in a single QSO and ignores GRIDSQUARE when more than one grid is in that field.
An adif exported logfile would need to include VUCC_GRIDS by swapping it for GRIDSQUARE when more than one grid is in that field.
WN4AZY on 2/1/2024(UTC)
#6 Posted : Wednesday, August 30, 2023 7:46:54 AM(UTC)
Just refreshing this, seems more and more VHF'er's that rove, especially the ones going after FFMA and working from a grid line or corner are becoming proficient at knowing how to upload multi-grid QSO's into LoTW. It would be nice to have multi-grid QSO's be correctly counted and exported (ADIF) as well as have them score correctly if contesting in LOGic BigGrin
WN4AZY on 8/30/2023(UTC)
#7 Posted : Friday, January 26, 2024 9:47:31 AM(UTC)
I'm feeling "lucky" so thought I would "gingerly" bump this one too....
I know this is easier said than done and not just as "simple" as adding a new field VUCC_GRIDS. Its Importing/Exporting LoTW (and other) QSL's, Adif exporting/importing, Awards Tracking (Progress and Reports) as well as Contesting and scoring. It also raises the user defined field limit of 20 unless of course it doesn't need to be a user-defined field.
a "ginger" Brad, K8ZM BigGrin BigGrin
#8 Posted : Thursday, January 30, 2025 6:45:52 PM(UTC)
A ginger bump....
Thanks, Brad K8ZM
Please see post #3 and #4 above as well.
WN4AZY on 2/4/2025(UTC)
