More on main log form
#1 Posted : Sunday, June 23, 2024 5:45:58 PM(UTC)
Dennis, is it possible to change the column headings from a mixture of upper/lower case to all upper case to make it easier to read?
#2 Posted : Tuesday, June 25, 2024 4:17:58 AM(UTC)
No, unfortunately not.
All-caps would result in much-wider text. Please consider choosing a larger font. However, that makes the data rows bigger too. I think there are all-caps fonts that you could use, but again that would make the data all-caps as well?
What to you think about making it possible to set the header font independently?
W5GA on 6/25/2024(UTC)
#3 Posted : Tuesday, June 25, 2024 12:40:06 PM(UTC)
Changing the both the font and font sized fixed it. Thanks, Dennis!
WN4AZY on 7/2/2024(UTC)
