LOGic8 to LOGic9 user defined fields
wd9hbc
#1 Posted : Thursday, June 14, 2012 9:48:28 PM(UTC)
Hi!
I upgraded and am having trouble with my user defined fields from v8. Everything was working fine there. When I installed v9 I imported a backup of the log. I also copied the data folder so that my field and screen setup would be setup like v8. However, none of the user fields are populated with data, although I know the data is there and all works fine in v8. Any help would be appreciated.
Thanks!
Jim, WD9HBC
#2 Posted : Sunday, June 17, 2012 8:51:18 PM(UTC)
Ok, you shouldn't copy the whole DATA or LOGDATA folder. The file structure is different. Fortunately there isn't much in DATA that was hurt. Just the prefix table and callbook. However, I would delete the contents of the DATA folder then reinstall LOGic 9 just to be safe.
Now, just copy your .logform file across. It is in the logdata\logforms folder. You will have to re-add your user-defined field setup in tools/setup/log fields. If this is the case you will be notified when you open your LOGic 8 log form in LOGic 9.
Let me know the specifics and we can proceed from there.
wd9hbc
#3 Posted : Tuesday, June 19, 2012 9:37:01 PM(UTC)
That did it. Just a reinstall and only moving .logform. Thanks!
Jim, WD9HBC
