POTA.APP
#1 Posted : Friday, July 28, 2023 6:21:07 PM(UTC)
Was thanked: 228 time(s) in 197 post(s)
Is it possible to include POTA.APP spots into LOGic??
There is a API:
https://api.pota.app/spot/activator
I currently use it in Node-Red but it doesn't pull in all the spots from POTA.APP for some reason. It could be the FLOW itself, I am mot sure. This would be a nice addition to LOGic especially with the growing popularity of POTA.
Just a thought. Hope all is well.
73 Kyle
WN4AZY on 8/1/2023(UTC)
#2 Posted : Tuesday, August 1, 2023 6:59:31 AM(UTC)
Hi Kyle:
Going OK. Hope to be in VA before summer is over, and look forward to stopping by.
So you are saying make this another spot source? I have worked with REST APIs before. Not too hard.
Notes to self and anyone else interested:
Paste the contents into here and it makes a lot more sense.
https://jsonformatter.org/
REFERENCE is the park identifier.
https://pota.app/#/
Tnx for the heads-up on this & 73,
#3 Posted : Wednesday, August 2, 2023 6:31:37 AM(UTC)
Yes, Quite a few spots that are shown on POTA.APP do not appear on the DX Cluster.
Thanks!!
#4 Posted : Thursday, August 24, 2023 5:41:20 AM(UTC)
This has been added to 10.0.119. Also POTA spotting. Be sure to enable the POTA record and turn on spotting in tools/Settings/Log fields....
Thanks for the suggestion!
#5 Posted : Thursday, August 24, 2023 7:16:26 AM(UTC)
AWESOME!!!
After enabling POTA I noticed that no USA/VE stations were being spotted. So I restarted LOGic and it's now working GREAT.
THANK YOU!!!
WN4AZY on 8/24/2023(UTC)
#6 Posted : Thursday, August 24, 2023 8:30:23 AM(UTC)
Works so much better than watching pota.app and a breeze when logging a contact!!! BigGrin
#7 Posted : Friday, September 8, 2023 11:07:55 AM(UTC)
Dennis, look at these and see what you think.
  • Add a Separate POTA Spot Log
  • Enable the Spot Log Form so it can be moved to another monitor
  • Add a "Turn On or Reset Radio Interface" button to the Rig Control Window
  • Band Map does not log POTA award value when clicking "Log"
  • Enable change Font Size in Band Map
Hope all is well.
73 Kyle
K8ZM on 9/8/2023(UTC), WN4AZY on 9/11/2023(UTC)
#8 Posted : Monday, September 11, 2023 8:26:13 AM(UTC)
Thanks for the suggestions Kyle.
You can filter the spot log to show only POTA. If I do anything, I will allow opening multiple spot log forms. Won't be easy....
Can already do that. You need to right-click on the backdrop of the form itself, not the pages. Not a lot of that type of real estate on the spot log. Try between the REDO and BAND buttons.
It would be a good bit of work, plus not sure if I want to take up room on every rig control panel. Maybe right-click something? I'll look into it, but in all honesty, don't hold your breath.
A bug. Will fix. Thanks.
Unfortunately, that would be very difficult. Most of the LOGic's Forms are done in Visual Foxpro, and we have librarys to support that. It is a trivial matter to add that feature to a form in Visual Foxpro. The band map is done entirely in .net. On the + side, the band map should set itself to match options chosen for your desktop, including font size.
#9 Posted : Monday, September 11, 2023 1:10:16 PM(UTC)
BigGrin multiple spot log forms would be great, thanks!
Thanks, I wasn't right clicking on the backdrop.
No problem
Thank You!
Not a biggie, thanks for the details.
73 Kyle
#10 Posted : Tuesday, October 17, 2023 8:55:18 AM(UTC)
Fixed in the new 10.0.23 update.
Thanks & 73,
