Posts: 467 Location: Missouri
Thanks: 100 times Was thanked: 157 time(s) in 139 post(s)
Dennis, I'm trying to run a grayline report, using default parameters for sunrise. I'm getting an error saying "variable 'DX' is not found". Telnet and spotlog are closed. Any ideas? 73 Doug W5GA 73 Doug W5GA
Hi-- The error sounds like you are running the LOGic 8 version of the report in LOGic 9. We removed the DX (distance) field from the prefix table -- easier to calculate it on the fly. Maybe the new report didn't make it to distribution. I will check. Attached is the working LOGic 9 report. Unzip and put in the REPORT folder, replacing the existing files. Tnx & 73, DH
That fixed it Dennis. Many thanks! 73 Doug W5GA
