Rig Setup and Control.
N6ELO
#1 Posted : Wednesday, February 15, 2023 6:51:40 PM(UTC)
I purchased a newer computer for my shack. It is running Windows 10 Home version.
I have a Kenwood TS-950S and a Yaesu FT-857D connected via two seperate data cables from rigs to computer USB ports.
I cannot get either one of them to connect to Logic 8.
I may need some instruction to get this ironed out.
Anyone familiar with setup of these rigs to Logic 8 and would like to assist, please contact me.
n6elo@citlink.net
916-769-1536 Jon
Pulaski, TN
#2 Posted : Thursday, February 16, 2023 8:06:43 AM(UTC)
Go to the Radio Interface in LOGic and select the Radio driver, the correct COM port, Baud rate, etc...
The COM port will probably not be the same as your old computer.
73 Kyle
WN4AZY on 2/16/2023(UTC)
#3 Posted : Thursday, February 16, 2023 10:35:06 AM(UTC)
This might help:
http://hosenose.com/Foru...ce-troubleshooting.aspx
Like Kyle says, it is basically of getting the correct COM port, baud rate, etc/
What is the first error message you get?
N6ELO
#4 Posted : Friday, February 17, 2023 10:06:06 AM(UTC)
Kyle,
Thanks, but I have tried it all with different settings being sure the computer matches the Logic parameters.
I'm getting the error message of Timeout.
#5 Posted : Friday, February 17, 2023 12:42:40 PM(UTC)
The timeout error is most likely due to no communications to the radio.
If the communications parameters match.
Make sure you enabled the radio in LOGic?
Has this worked before?
Try another cable?
WN4AZY on 2/20/2023(UTC)
N6ELO
#6 Posted : Friday, February 17, 2023 3:13:36 PM(UTC)
Yeah...I ordered a new cable. It is a cheapeee and one of the ones that are not dependable.
