LOTW Certificate Glitch
ka5swc
#1 Posted : Friday, February 10, 2023 3:27:28 PM(UTC)
I am just getting back into the hobby and I have made two LOTW uploads, but there is a glitch it seems. From what I could see, my LOTW certificate is still in effect, however LOTW shows my last up in 2010. As I have made two uploads, those cards are marked with a check. Is there a way for me to run a batch file and "uncheck" these so that I can re-upload them?
John/KA5SWC
#2 Posted : Friday, February 10, 2023 5:22:31 PM(UTC)
Yes, LOGic has a good bulk updater. https://youtu.be/5d5gyJVFQEs Please like/subscribe to our youtube channel.
However, I do not believe this is the best way to go about it. There is a SELECT CRITERIA box in the Upload to LOTW form. If you want to reupload everything since a certain date, click the ... button and fill this out.
In the ADIF EXPORT OPTIONS popup that appears, uncheck the box that says "Do not export if already uploaded to LOTW."
ka5swc
#3 Posted : Friday, February 10, 2023 7:11:09 PM(UTC)
Thanks Dennis! Your suggestion of the SELECT CRITERIA did the trick!
73's de KA5SWC
John W
1 user thanked ka5swc for this useful post.
WN4AZY on 2/13/2023(UTC)
w7gtf
#4 Posted : Tuesday, June 13, 2023 3:07:53 PM(UTC)
Thanks Dennis-
Just had an issue with CQ-WPX contacts not showing up on LOTW. Your suggestion above did the trick
Ron/W7GTF
1 user thanked w7gtf for this useful post.
WN4AZY on 6/13/2023(UTC)
