10.0.10 Update
NU1B
#1 Posted : Tuesday, November 22, 2022 11:32:14 AM(UTC)
Hi Dennis
I updated to 10.0.10 this morning and when I went to import from LOTW< i got the following errors
OLE error 0x80070057: the parameter is incorrect
Hit cancel
unknown member controlpanelref
hit cancel
unknown member browseref
hit cancel
unknown member pageframie1
hit cancel - same error message as before and finally hit cancel again program closed
I when back and reinstalled 10.0.09 for now until this problem is fixed
Please let me known if there is something I need to do to resolve this error
Steve, NU1B
1 user thanked NU1B for this useful post.
WN4AZY on 11/23/2022(UTC)
NU1B
#2 Posted : Wednesday, November 23, 2022 10:40:28 AM(UTC)
Hi Dennis
I redownloaded and reinstalled 10.0.10 this morning When I import from LOTW i am since getting the same mkessage as before
Steve NU1B
ns4c
#3 Posted : Wednesday, November 23, 2022 12:05:24 PM(UTC)
Same issue with the update. Reverted back to previous version.
Bill NS4C
N3HR
#4 Posted : Wednesday, November 23, 2022 2:45:39 PM(UTC)
Steve,
Im having the same error message when trying to link the log in WSJT-x program to Logic log. Everything worked fine before upgrading to the latest version.
Mike N3HR
#5 Posted : Wednesday, November 23, 2022 8:18:17 PM(UTC)
Thanks for the report. Sorry.
Please download and install the update again.
N3HR on 11/27/2022(UTC)
NU1B
#6 Posted : Thursday, November 24, 2022 8:23:22 AM(UTC)
Hi Dennis
I downloaded and reinstalled 10.0.10 this morning. When I import from LOTW, I still get the same errors as before
I reinstalled 10.0.09 for now
Steve, NU1B
W5GA on 11/24/2022(UTC)
#7 Posted : Thursday, November 24, 2022 11:03:55 AM(UTC)
Sorry guys -- I messed up again last night. Please download and install again. I reproduced the LOTW error here, updated just like everyone else does, and it works!
W5GA on 11/24/2022(UTC), N3HR on 11/27/2022(UTC)
#8 Posted : Thursday, November 24, 2022 11:41:20 AM(UTC)
Thank you Dennis...it all works here now BigGrin
Happy Thanksgiving !
NU1B
#9 Posted : Thursday, November 24, 2022 5:33:02 PM(UTC)
HI Dennis
I reinstalled 10.0.10 and everything is working fine
Thanks for your help
Steve, NU1B
WN4AZY on 11/25/2022(UTC)
NU1B
#10 Posted : Sunday, November 27, 2022 4:23:15 PM(UTC)
Hi Dennis
I had no problems with 10.0.10 until I made a WSJTX contact When I clip okay in WSJTX to log the contact I get the following errors in Logic
error1426 ole error code 0x80004002 no such interface support has occurred in program importadifrecord.import, line 32
Hit yes to continue you get the following error
error 12 variable fldinfo is not found has occurred in program importadifrecord.import, line 84
hit no to not continue ou get the following error
variable call id not found
Hit cancel and program shuts down
I appreciate help in resoving this import issue with WSJTX
Steve, NU1B
#11 Posted : Sunday, November 27, 2022 4:31:05 PM(UTC)
How long ago did you download 10.0.10? Please try deleting logicupdate_10.0.10.exe from your system and downloadingit again and installing again. I was able to repeat the problem. I fixed the code. I downloaded from the server the same way you do, installed it, and do not get the error.
I am at 770-307-1511 right now if you want to call.
NU1B
#12 Posted : Sunday, November 27, 2022 5:42:56 PM(UTC)
Hi Dennis
I downloaded 10.0.10 2 days ago and had no problems with importing from LOTW. However, today I worked a couple of FT8 contracts and when I hit log QSO in FT8 I got the error messages described above. I just downloaded 10.0.10 and reinstalled again. I will let you know if I still getting the error messages when I work a FT8 contact
Thks & 73
Steve, NU1B
#13 Posted : Sunday, November 27, 2022 8:11:35 PM(UTC)
That was fixed a day or two ago.
I have been trying without success to include a 4th digit in the version for fixes -- i.e. 10.0.10.2
What I did manage is to do just now is to include the compile date and time in the description of the exe properties. It is not in the current update, but will be in the next.
N7IP
#14 Posted : Monday, November 28, 2022 9:14:10 PM(UTC)
After the 10.01 update, the spot log is now showing lots of 160m data spots that are already confirmed and show at F in the progress windows.
Bob
#15 Posted : Tuesday, November 29, 2022 5:07:51 PM(UTC)
Hi Bob:
I can't think of anything we changed that would affect that.
Are they showing up in the spot log as not needed? Make sure that the SHOW ALL checkbox is off.
But that would cause all bands to show up whether needed or not. I set the prefilter filter to pass only 160M spots, and hokey'd up some spots for QSOs already confirmed, and see no problems here.
Maybe post a screen shot and I'll see something.
This page was generated in 0.074 seconds.
