Ok, I played around with it. It seems XML-RPC is on by default. in FLDIGI, go to Configure/Config Dialog/Misc/TCP-IP sessions. The XML line should have 127.0.0.1 for the address and 7362 for the port. If it is not set up this way, uncheck LOCK and click the DEFAULT button for XML. Save your config and restart fldigi. The Restart button does not seem to work.
Now run LOGic. Whatever you type in the transmit window shows up in fldigi.
Get LOGic and fldigi working without the rig first. You may have to unblock 127.0.0.1:7632 in your firewall.
When it comes time to connect the rig, connect it to LOGic as usual. Do not attempt to interface the rig to fldigi.
Make sure fldigi is running before starting LOGic, and do not close fldigi without closing LOGic first.
Hope this helps. Let me know.
