can't log after updating to Logic 10
WB3ESR
#1 Posted : Friday, October 15, 2021 7:12:58 PM(UTC)
Hi Dennis!
I just downloaded Logic 10 you sent me after renewing my subscription. Logic 10 seemed to load OK and says my subscription is extended to October 29, 2022. However, I tried logging a contact from WSJT and received the following message: OLE error 0x8002000s, invalided number of parameters. The following message also appeared: Program error "variable call is not found." After clicking on "ignore" etc., the program crashes and I must restart by going through the "clean" process, etc. I tried numerous times and same thing happens. I also tried entering a call directly into the log (not through WSJT) and same thing occurs with same error message. In other words I can't do anything and it has not worked since I installed it...
Help!
**Gil**
(now K3BLN)
WB3ESR
#2 Posted : Tuesday, October 19, 2021 5:56:11 PM(UTC)
I have reloaded program and still same problem. I can't use Logic
Gil
WB3ESR
#3 Posted : Tuesday, October 19, 2021 6:45:39 PM(UTC)
no need to reply. Since I hadn't heard from you I again downloaded the update associated from my subscription renewal, and no change...I still could not log new QSOs. I kept getting error messages and other messages as outlined in my previous message. So, I reinstalled the latest version as found by clicking the help button. That seems to have corrected the problem. I wish I would have thought to do that 4 days ago.
Gil, WB3ESR, now K3BLN
#4 Posted : Wednesday, October 20, 2021 5:48:35 AM(UTC)
Hi Gil:
I apologize for the delay in getting back to you. Glad you figured it out.
gain, I apologize.
Tnx for using LOGIc.
