Counting and reporting are different
#1 Posted : Sunday, September 5, 2021 3:56:30 PM(UTC)
I wanted to make a statistic on QSOs made with unique Italian CALLS.
As you can see from the attached screenshots the result of the count with the filter is correct while when I go to print the report they are much less, even only a third of the total. How is it possible?
Thanks from IKØCHU Mauro
#2 Posted : Monday, September 6, 2021 5:52:14 AM(UTC)
I reflected on the results obtained. Could it be that the list with the filter counts all the QSOs with Italians while the report prints only the first of the QSOs made with a CALL if there should be more than one ???
Eventually how can I do to print all the QSOs?
Thanks 73 de IKØCHU Mauro
#3 Posted : Wednesday, September 8, 2021 7:49:40 PM(UTC)
Hi Mauro:
The filter will show a count of all QSOs with any I or IS0 station. I can't see what you did to set up the Awards report, but it looks like you are on the right track. An awards report normally shows each value only once now matter how many times you work it.
Here is how I would do it: Set up a new award like the photos. Then you can do mixed, band, mode, etc. If you want to.
Tnx for using LOGic.
