LOGic Forum
LOGic Support
Installation & Updating
telenet2 window change in version 9.21.4
Thanks: 1 times Was thanked: 8 time(s) in 6 post(s)
After upgrading Logic from version 9.21.3 to 9.21.4 a change in the telnet2 form was noted. The telnet2 window is larger and has function keys on the right side of the window. The window cannot be resized to eliminate them or as small as previous. These used to be buttons on top of the window. The new format may be great for some but now I can't resize the window small enough to fit in its original screen location. This messes up the layout I have for all the Logic windows I have open on my display. I don't use function keys so this is just wasted space in this window. I can't find a way to get rid of the function key descriptions. I did not read that the new version would cause this to happen. How do I get rid of it? Setup for this screen does not allow me to turn off or to place the function key buttons where I want them. This is not a serious issue but aggravating. Can I go back to version 9.21.3 and get rid of the new telenet2 form? Thanks for any help.
1 user thanked K4ZO for this useful post.
Groups: Administrators, Beta Testers Posts: 3,260  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
I put the labels on the side so they could be wide enough to display the short description instead of 1 2 3 4 ....
In the next update, you will be able to shrink the form down to hide some of the lower buttons -- they aren't used by most customers anyway. IN the meantime, I don't see any problem with backgrading to .3.
LOGic Forum
LOGic Support
