Contest Summary w/Multiplier List report error
#1 Posted : Monday, March 29, 2021 12:29:20 PM(UTC)
Just finished the CQWW WPX contest and when running the Contest Summary With Multiplier List report I get this error when printing to a printer or pdf.
Error 12 "Variable 'MULT_TOT_PRECALC' is not found." has occurred in program RUNREPORT.PRINTREPORT, line 68
Snip attached.
I have had this occur before, including last years ARRL DX and CQ contest summaries when the multiplier list is printed. The report without the multiplier list runs fine.
LOGic v9.21.2
Windows 10 Pro v20H2
Thanks for any ideas,
Brad, N8GLS
#2 Posted : Friday, April 2, 2021 1:43:22 PM(UTC)
I'll look into this today.
#3 Posted : Sunday, April 4, 2021 8:35:46 PM(UTC)
Sorry for the delay on this.
It was seemingly very intermittent. However, I found out that if you run the report once, then run it again without closing the run report window, this error occurs.
Attached is a fixed report, which admittedly hasn't had a lot of testing. It does seem stable, so give it a try if you want. Unzip into C:\Program Files (x86)\LOGic\report
Otherwise, just close the run report window before rerunning.
CONTEST SUMMARY WITH MULTIPLIER LIST.zip (9kb) downloaded 120 time(s).
K8ZM on 4/5/2021(UTC)
#4 Posted : Monday, April 5, 2021 11:30:46 AM(UTC)
Yes, it did not occur 100% of the time but seemed more frequent than I remembered. Anyways, seems fine but will try at random times over the next few weeks and report back.
Thanks for the fix !!
73 de Brad, N8GLS
WN4AZY on 4/8/2021(UTC)
