9.20.12 update available
#1 Posted : Monday, November 16, 2020 11:32:07 AM(UTC)
Fixed French Union callbook to use new URL.
Import LOTW QSLs now provides a definitive "Username/password incorrect" message instead of just displaying the error page HTML.
It is no longer necessary to attempt to download QSLs before right-clicking the IMPORT DIRECTLY FROM WEB button to get the URL being used by LOGic to download QSLs. You may get the URL before attempting a download.
Tools/Check for Updates now displays a link to renew your update subscription, starting 30 days before the actual expiration.
New prefix exceptions file, November 11, 2020. Version is Republic of the Congo, TN. To view version, open Forms/Info, and type VERSION in the Prefix field .
To download the update, go to help/check for Updates in LOGic. If your subscription has expired, please go here to renew it.
http://www.hosenose.com/...mp;PrimaryCatID=44&
K8ZM on 11/16/2020(UTC), w2zi on 11/17/2020(UTC)
#2 Posted : Monday, November 23, 2020 4:38:03 PM(UTC)
I notice 9.20.14 is available however, when I try to update (either by using LOGic updater or HELP > Check for updates), I get an error message with a lot of text that begins with:
"Install LOGic Update: An unhandled exception occurred"
mscorlib: The maximum message size quota for incoming message (65536) has been exceeded. To increase the quota, use the MaxReceiveMessageSize property on the appropriate binding element".
Any idea what this is?
#3 Posted : Monday, November 23, 2020 9:38:38 PM(UTC)
Same here, attached is the error message. Running v9.20.13 which had otherwise worked great since its install just before the ARRL Nov Sweeps, also worked great during the contest this weekend. I ran updater (LOGic not running) and the error immediately pops up. I'll try to re-install 9.20.13 again and see if that does anything.
Update: Re-installed and still get the error.
73, Brad N8GLS
#4 Posted : Tuesday, November 24, 2020 9:51:02 PM(UTC)
Sorry for the problem. You have an old config file. A newer one is needed to handle the number of update records that are sent by the server. It was fixed long ago, but somehow an old file got introduced into the works somehow. Installing 9.20.13 caused the problem.
An update to the updater is attached. Please download it and run it.
Again, I apologize.
Tnx for using LOGic.
LOGicUpdaterSetup.exe (1,657kb) downloaded 208 time(s).
#5 Posted : Wednesday, November 25, 2020 9:05:15 AM(UTC)
All is good !! Thanks for the quick fix !!
Happy Thanksgiving to all !!
Brad, N8GLS
WN4AZY on 11/25/2020(UTC)
