How to create QSL with mockup ?
F6hnx
#1 Posted : Wednesday, August 26, 2020 1:47:59 AM(UTC)
I created a QSL card mockup including: photos + locations of fields corresponding to those of the LOGIc 9 log.
The objective is to be able to print the fields of the log, for example the information of the QSO contact under the field of the model.
How to create the model to do this ?Blink mockup QSL
#2 Posted : Thursday, August 27, 2020 3:52:25 PM(UTC)
Hi Serge,
Not sure if you have looked at any of LOGic's QSL reports but that is the best place to start. Navigate to Reports, QSLing and click on QSL Cards, that will pop-up a window with many pre-existing QSL Card reports, some will print multiple QSO's on a card, some a single QSO per card, some print multiple cards per sheet, others a single card. Try to find one that is close to your design layout and it can be copied and modified to what you need. Also, take a look in LOGics help and the topic "Report Writer" and "Customizing Your Own Reports", both are good sources of info. Also, check out YouTube video https://youtu.be/_8CBFNuL8x0 ,it describes how to change the size of a card within a QSL Card report.
I have old style QSL cards with pre-printed fields on the back of the card and easily modified one of LOGic's pre-existing QSL Card reports to match the data field locations on the card. It works very well.
Let us know and we can try to help with modifying an existing report to get what you need.
73 de Brad, N8GLS
WN4AZY on 8/31/2020(UTC)
#3 Posted : Friday, August 28, 2020 1:16:03 AM(UTC)
Serge,
Glad to help....I sent you an email with detailed instructions on how to get started. Let me know and I can help with the modification.
73 de Brad, N8GLS
F6hnx
#4 Posted : Friday, August 28, 2020 5:38:19 AM(UTC)
Hello Brad
I have just finished configuring a QSL model (* .rep file).
The result is convincing; I find exactly the same functionalities as with an older version of LOGIc.
Thank you for your help, because over the years I couldn't remember what to do next.
cordially
Serge (F6HNX)
1 user thanked F6hnx for this useful post.
K8ZM on 8/28/2020(UTC)
#5 Posted : Friday, August 28, 2020 10:11:58 AM(UTC)
Serge,
Glad you were able to get back into modifying the report, just yell at us on the forum if you need anything !!
73, Brad, N8GLS
#6 Posted : Monday, August 31, 2020 9:50:53 AM(UTC)
Brad: Thanks so much for your help.
Serge, I apologize for the delay in my response. I did get your email BTW.
Here is some more info that might be useful to you or someone:
http://hosenose.com/Foru...difications.aspx#post18
Also a couple specific questions are addressed here:
https://www.youtube.com/...ZwA/search?query=report
Let me know if you need additional assistance with this.
#7 Posted : Tuesday, September 1, 2020 9:24:07 AM(UTC)
Hope you guys are ok !! No thanks necessary, that's what the forum is for and the least we can do !
Glad to see you "back" !
73 de Brad, N8GLS
