MixW and Logic9
#1 Posted : Sunday, March 11, 2012 6:00:29 PM(UTC)
I tried to use MixW with Logic 9 and i received an error.
An image in the attach file.
Can you help me?
Thanks de IKØCHU Mauro
#2 Posted : Tuesday, March 13, 2012 10:17:21 AM(UTC)
Hi Sante:
Thanks for the note and picture.
This error is coming from the sound system. Are you using a sound card for anything in LOGic? I see you have ANNOUNCE checkmarked.
I would say turn off ANNOUNCE to test, but someone discover a bug where the spot log opens the sound card even when Announce is turned off. Try selecting a different sound card.
#3 Posted : Tuesday, March 13, 2012 1:34:53 PM(UTC)
Hello Dennis,
thanks for the answer.
I think I've discovered the reason for failure.
The MixW program has nothing to do. In fact the error depends on some sound file but the logic does not know it. I noticed that the error only shows when, in the logform used, is inserted into the setup the first variable V1 in the voice player.
The error received because I had inserted, in the path of the first memory voice keyer, a wave file sampled at 44 kHz so it wasn't read. After editing that file in the correct format error was gone but was activated voice keyer memory number V1. Then a change to the QSO's as if you click the Voice button keyer1. If you remove the memory number 1 the problem does not exist. This is my experience on the problem.
I hope will be usefull to found the right way to eliminate the problem.
An eye at attached screenshots.
73's de IKØCHU Mauro (Hi ... Sante is a friend of mine)
Guest (5)
