Groups: Administrators, Beta Testers Posts: 3,260  Location: Auburn, GA Thanks: 1140 times Was thanked: 555 time(s) in 465 post(s)
Does MixW 4 create an ADIF file in real-time as you log? If so, find out where it stores this file. Click the SELECT button in Auto ADIF LOGGING, locate the ADIF file, and double-click it.
Some troubleshooting steps are to look at the MixW ADIF file after logging a QSO to make sure it is getting added to the ADIF file.
The old MixW did not create an ADIF file in real-time that I am aware of. It used a DDE interface. You can try that. In the Log menu, click MIXW INTERFACE.
