New Clublog Export
#1 Posted : Thursday, March 13, 2025 4:54:40 PM(UTC)
Tried using the Clublog export today. I have a couple of questions Dennis:
1. I didn't want to export my entire log so I went back to my last Clublog export date and only exported those records on or after that date. After export, the "Clublog s" field showed a checkmark, ok good. Now I want to show a check for ALL records before the previous Clublog export date (11/26/2024), so I don't have to use a filter command when doing the export. How do I do that with a mass change?
2. It appears that all the program does currently is export all of this to a file, correct? It does not actually upload the file to Clublog. Please confirm.
3. Please change the field name "Clublog s" to "Clublog sent".
4. Please either add a date to the export file -or- complete the implementation to do the upload.
#2 Posted : Thursday, March 13, 2025 8:30:33 PM(UTC)
use log
replace all clublog with .t. for qso_date<{^2024/11/26}
You are correct. That will change
Internally, it is called simply "clublog". You are referring to the label. I feel it would be simply wasted real estate. Hold your mouse over the checkmark, and it will tell you what the field does.
You mean add the date and time to part of the file name? Good idea. Will do.
Thank YOU!
N5XZ on 3/18/2025(UTC)
NS4X
#4 Posted : Saturday, March 22, 2025 3:46:53 PM(UTC)
I need to do this (mass update of the Club Log sent field), so I searched and found this thread. However, using "replace all clublog with .t. ..." returns a variable not found error. I am familiar with using database commands (I routinely use them to change the entry in the power field following a contest, for example). Any help would be appreciated!
Bart, NS4X
#6 Posted : Saturday, March 22, 2025 10:23:51 PM(UTC)
You'll likely get better/quicker response by starting another thread.
Doug W5GA
#5 Posted : Tuesday, March 25, 2025 8:26:25 AM(UTC)
Bart, NS4X
Bart, it worked for me. Are you hitten the enter key after "Use log'?
WN4AZY on 4/6/2025(UTC)
NS4X
#7 Posted : Saturday, March 29, 2025 4:17:41 PM(UTC)
Allen,
I was hitting Enter after the use command. I deleted all my previous attempts and typed it in fresh...and it worked! I must have had a typo somewhere that I missed. Thanks!
1 user thanked NS4X for this useful post.
#8 Posted : Sunday, April 6, 2025 8:51:41 AM(UTC)
I copied and pasted my example to test. It works. Be sure to press {Enter} after each line.
#3 Posted : Wednesday, April 30, 2025 8:07:31 PM(UTC)
Thank YOU!
WN4AZY[/quote]
I know how you hate to give an ETA, but ... any updates???
