FFMA Award, Progress and Reports
#1 Posted : Thursday, June 1, 2023 2:23:41 PM(UTC)
Was thanked: 188 time(s) in 168 post(s)
I'm actively in the FFMA chase, that said when I try to use Progress and select FFMA nothing shows, if I select Grid it displays correctly (of course progress for all bands). When you run an awards report and select FFMA, you have to specify the band to be 6m or else you'll get FFMA status for any/all bands. FFMA is a 6m award and doesn't apply to any other band. Funny I never reported this before but I was trying to set Progress 2 to FFMA but it didnt show anything, leaving it set to Grid it displays but of course it shows all grids worked by band and not just the 488 grids on the 6m band.
Would be nice to have the FFMA Progress window be able to show progress for the 488 grids on 6m only. At least the reports can be filtered by band/mode which I can easily live with.
Thanks for any consideration !!
#2 Posted : Wednesday, June 7, 2023 8:09:38 AM(UTC)
Was thanked: 500 time(s) in 414 post(s)
Exactly which awards report are you using? The regular old AWARDS report?
The expression for FFMA (a calculated field) excludes all non-6M.
BAND="6M" AND LEN(ALLTRIM(GRID))>=4
#3 Posted : Wednesday, June 7, 2023 9:01:21 AM(UTC)
Hi Dennis, hope your all well !!
Ok, so, I have two things;
1) Using the Awards Progress Display 2 and selecting the FFMA sub-award displays no results at all.
2) Running the AWARDS report, if you select the sub-award FFMA it includes results for all bands, not just 6m, so you have to filter it for only 6m. If that sub-award is supposed to exclude all but the 6m band its not. Maybe that report is out-of-date on my system.
#4 Posted : Wednesday, June 7, 2023 4:34:35 PM(UTC)
I am seeing this also. Navigating to a 6-meter QSO with GRID logged does not update the display. That is a problem. However, you can manually pick the Grid in question from the dropdown on Progress Display 2. That works.
Not seeing that at all. I just run the Awards report, select FFMA and nothing else, and I get FFMA-eligible QSOs only. Print Unworked Entities works too.
On my copy, the FFMA award is disabled by default. Be sure to enable it, then do UPDATE AWARDS PROGRESS INFO.
I'll look into the refresh problem with #1. Let me know if FFMA is enabled.
#5 Posted : Wednesday, June 7, 2023 5:39:27 PM(UTC)
1) ok, yes. I reverted to just leaving display 2 set to Grid and look at the 6m column. I sorta know if the station is in one of the 488 grids. Dont knock yourself out, the fix could be whenever.
2) So yes FFMA was enabled and in Awards Tracking its checkmarked to track awards for this field, but not sure if the expression for the calculated field in Awards Tracking and Spotting is right, its "LEFTDELIM(GRID,4","), the Filter looks right "BAND="6M" AND LEN(ALLTRIM(GRID))>=4". Funny, now that I think about it I have never seen any spots with sub-award FFMA. Confused
Just to be sure i'm not missing something here is pic.
#6 Posted : Wednesday, January 24, 2024 7:53:50 PM(UTC)
Hi Dennis, hope all is well !!
Running LOGic v10.0.26 - Still an issue with having to filter the FFMA Awards report to get results for ONLY 6m. If the band selection is left blank it returns ANY band, see attached.
The FFMA award is enabled and I'm running the native Awards Report, also attached is a screen shot of the calculated field expression.
Any ideas ??
Second issue not as pressing is the "print unworked entities" checkbox. If checked it works fine for the first report. If you print a second report immediately after the first, that checkbox remains checked and clearing the checkbox then printing still prints the unworked entities. You have to clear the checkbox then get out of that screen (either by "Next" or "Previous") then get back into the same screen before it will remember the checkbox was cleared. Its like it remembers it was checked initially but won't clear the checkbox when the report closes
#7 Posted : Thursday, January 25, 2024 3:31:10 PM(UTC)
Thanks for bumping this. Next on my list.
K8ZM on 1/26/2024(UTC)
#8 Posted : Thursday, January 30, 2025 6:42:25 PM(UTC)
Hi Dennis, hope your well !!
Bumping both the above issues. Running 10.0.29 and same issue.
Sorry but have a couple more that are more work Mellow
Guest (4), K1VC
