Set active RIG via radio command, PTT, or other
8/15/2018 9:30:33 AM(UTC)
2
11,011
8/15/2018 4:16:02 PM(UTC)
Issue with K3 control
7/4/2018 9:17:43 AM(UTC)
15
35,592
7/16/2018 9:14:03 AM(UTC)
Interfacing Icom 7300 with LOGic 9
WB3ESR
5/17/2018 9:36:44 PM(UTC)
8
19,829
7/12/2018 8:22:37 PM(UTC)
New and improved serial port support for LOGic
6/5/2018 2:50:36 PM(UTC)
13
34,008
7/8/2018 11:48:59 AM(UTC)
IC-7610
2/26/2018 2:51:16 PM(UTC)
7
22,299
3/26/2018 2:16:24 PM(UTC)
Logic is locked up after rig interfacing
kk4cb
2/25/2018 2:32:51 PM(UTC)
6
17,645
kk4cb
2/27/2018 8:04:13 AM(UTC)
interfacing a Channel Master Rotor (3 conductor)
w3bs
4/18/2017 12:19:19 PM(UTC)
0
8,485
w3bs
Reading data stream of "Set Rig"
4/11/2017 11:03:55 AM(UTC)
2
12,916
4/17/2017 9:28:57 AM(UTC)
Program stops working when entering a call
N7TB
12/27/2016 4:09:24 PM(UTC)
5
22,030
12/30/2016 10:43:13 AM(UTC)
IC-7100: Problem with CI-V address 88h
DL6JZ
12/5/2016 2:16:28 PM(UTC)
3
16,009
DL6JZ
12/17/2016 11:55:57 AM(UTC)
Elecraft K3S interfacing
NS4X
11/22/2016 10:17:37 AM(UTC)
1
9,582
11/23/2016 8:19:11 AM(UTC)
FLDigi
9/11/2016 8:31:15 PM(UTC)
6
19,865
9/29/2016 9:14:08 PM(UTC)
Fldigi & multiple Radios inteconnected to Logic
9/22/2016 3:54:34 PM(UTC)
2
12,080
9/23/2016 12:27:03 PM(UTC)
LOGic comms times out when using RTTY
9/20/2016 12:07:38 AM(UTC)
7
21,184
9/21/2016 8:30:31 PM(UTC)
ICOM 7300
kq5s
9/4/2016 1:17:48 PM(UTC)
1
9,436
9/6/2016 9:42:26 AM(UTC)
