Accessing user-defined fields via LOGic's COM interface
#1 Posted : Tuesday, July 15, 2014 10:04:08 AM(UTC)
Was thanked: 487 time(s) in 402 post(s)
There is a method of the log form named
write_userfield() that takes three parameters:
The Tag
The Value
Overwrite existing data
So for example
Log.write_field "NAME", "FE", True
Log.write_userfield_field "IOTA:", "AF-001", True
(where Log. is the reference to the log form in your code).
To read a user-defined field,
name = Log.read_field "NAME"
iota = Log.read_userfield "IOTA:"
You can also specify the return type:
Log.read_userfield("IOTA:", "C")
Valid types are:
"C" returns Character (default)
"D" returns Date
"I" returns Integer
"F" returns Float
"L" returns Logical
This page was generated in 0.015 seconds.
