Update problems with WWA Calls
#1 Posted : Thursday, January 18, 2024 5:05:39 PM(UTC)
proceeding to update the data from Qrz.com with the "Calbook Batch Update" I have the problem that the WWA calls block the update and I have to forcefully close the Logic with Ctrl-Alt-Del. I then tried to put a filter and detect all the Calls that have a WWA suffix to update them manually but the Logic Callbokk fails. What is going on? Does it only happen to me? I asked other colleagues who however use other log programs and for example even BBlogger does not allow automatic updating but does allow it during manual updating. Thanks for the attention.
73 of IKØCHU Mauro
#2 Posted : Sunday, January 21, 2024 10:54:21 AM(UTC)
Was thanked: 487 time(s) in 402 post(s)
Do you have the QRZ Subscription? The QRZ.COM web site is very difficult to work with due to his login requirements, etc. However, it is working here.
See the attached screen shot. Give me one of your calls to try.
#3 Posted : Monday, January 22, 2024 3:30:11 PM(UTC)
don't worry about the delay, ours is a hobby and not a job, hi.
I made a filter for all the QSOs that I couldn't update both automatically and manually, there are 11. If you look carefully, I overcame the problem by putting a character in the NAME field to proceed with the automatic updating.
I am registered with Qrz.com XML and I have never had any problems except with an Italian call which most of the time blocked Logic. And it's still doing it, in fact if I see I've connected it I first do it manually waiting a bit of time but it works.
Then I proceed with the automation.
Greetings Mauro IKØCHU.
Screen Shot 22-01-24.PNG (107kb) downloaded 14 time(s).
#4 Posted : Monday, January 22, 2024 6:04:49 PM(UTC)
I will look thru your post. Meantime, I tried II5WWA and it works.
Tnx for your patience.
