Groups: Administrators, Beta Testers Posts: 3,067 Location: Auburn, GA Thanks: 979 times Was thanked: 487 time(s) in 402 post(s)
I am not seeing that here. To verify, I went to tools/setup/list of valid values and deleted DXCC. I then reinstalled 10.0.2 (Be sure to checkmark to install new lists), and only EU Belarus shows up. So not sure where yours came from.
You can fix it as described above, or it would be easier to fix it manually. Do you have EU Belarus? If so, delete the two EWs. If you do not have EU Belarus, delete the blank EW and change the EW Belarus to EU.
Sorry for the trouble. Let me know if EW appears again.
