LOgic 9.1.0
NU1B
#1 Posted : Wednesday, August 17, 2016 9:04:19 AM(UTC)
Hi Dennis
I downloaded and installed the new version. The telnet window would not connect to host. It would start the login process and would stop after the login command was sent. I try a different host and got the same results. I also restarted my computer and got the same results after the restart. I reinstalled version 89 and everything works fine
Ant ideas what the problem may be
Thanks & 73
Steve NU1B
#2 Posted : Wednesday, August 17, 2016 10:30:03 AM(UTC)
Was thanked: 522 time(s) in 436 post(s)
I found the problem -- it wasn't sending a carriage return after the responses for prompt/response login. Go ahead and get the 9.1.1 from Help/Check for Updates. That fixed it here.
NU1B
#3 Posted : Wednesday, August 17, 2016 12:15:19 PM(UTC)
Hi Dennis
I just re-downloaded 9.0.1 and got the same result with the telnet issue
I am going to reinstall version89 for now
Steve, NU1B
#4 Posted : Wednesday, August 17, 2016 12:17:46 PM(UTC)
Right -- 9.1.0 has a problem. You need to install 9.1.1. Install 9.0.1, Run LOGic, then in LOGic, click Help/Check for updates, and install 9.1.1.
K8ZM on 8/17/2016(UTC)
#5 Posted : Wednesday, August 17, 2016 10:45:27 PM(UTC)
Was thanked: 218 time(s) in 195 post(s)
Thanks Dennis!
All working fine now. Updater is nice!
73, de Brad N8GLS
#6 Posted : Sunday, August 21, 2016 6:00:40 PM(UTC)
I tried to install 9.1.1 using the Help/Check for Updates in the Logic 9.0.1.
This is the error message received and the Logic restart. (Screenshot attached)
Thanks for help.
73's Mauro.
