3 Pages<123
LOGic 9 Program Update -- new features and fixes
#100 Posted : Thursday, December 17, 2015 3:36:43 PM(UTC)
Was thanked: 556 time(s) in 466 post(s)
Dec 17, 2015 9.0.80
Uses .Net framework 4.0 exclusively. You no longer need .Net 3.5/2 installed on your computer. If you get an error about .Net 4 needing to be installed, get it here:
https://www.microsoft.co...d/details.aspx?id=17851
*Fixed problem with calculated fields (CQ Field and FFMA for example) not tallying awards.
*Fixed problem with lookup of some callsign exceptions such as FR/OH2YL not being looked up when entered in the prefix table.
*Implements latest version (Dec 2) of BIG CTY file for callsign exceptions.
*Latest version of DirectX implemented (used by LOGic for sound). A problem with sound card errors fixed.
*Sound can be disabled altogether by going to the control panel and uninstalling the SlimDX library. After you do that, LOGic will error when you attempt to play a sound, but will disable sound for subsequent startups. To re-enable sound, reinstall the SlimDX library (this can be done by installing this update), then checkmarking the Sound Enabled control on the Announcements tab of the Spot Log.
Dec 28, 2015 9.0.81
*Fixed error with voice keyer introduced in 9.0.80.
logic9update81.exe (12,338kb) downloaded 1,002 time(s).
#101 Posted : Monday, January 11, 2016 8:42:02 PM(UTC)
January 11, 2016 9.0.82
  • Telnet prompt/response for auto login has been simplified. You no longer need to be concerned with what is sent after the prompt. For instance, ENTER YOUR CALL:, ENTER YOUR CALL:{space}, or ENTER YOUR CALL:{return} sent by the host can all be handled the same in LOGic by simply telling it to watch for YOUR CALL:
    How this works: When LOGic sees the string you entered, it waits .3 seconds and sends your response. It no longer waits for the host to stop transmitting before checking what was sent.
  • Fixes problem when logging 4Z/3Z9DX and similar calls. LOGic's live prefix lookup would croak when you typed 4Z/3, as it is an invalid call.
  • Latest CTY.DAT prefix exceptions from Jan 4.
logic9update82.exe (13,177kb) downloaded 1,045 time(s).
KA1J on 1/14/2016(UTC)
#102 Posted : Monday, February 15, 2016 8:23:31 PM(UTC)
Feb 15, 2016 9.0.83
  • No longer relies on browser to log into LoTW to download your data.
  • Latest CTY callsign exception list.
  • Updates now contain the whole LOGic installation. This will simplify distribution, and will potentially fix more problems with a corrupted installation. Update downloads also take longer.
    As with reinstallation from your original distribution copy of LOGic, your data and setup will not be overwritten. However, as always, keeping a backup of your LOGic install folder is recommended. Also, a new option has been added to overwrite the existing prefix table with a factory copy.
    You will still need a copy of your original installation or a copy of your license file (logic.lic) to do a complete install on a new machine.
LOGic9Update83.exe (40,786kb) downloaded 928 time(s).
4 users thanked WN4AZY for this useful post.
kg8cw on 2/21/2016(UTC), KA1J on 2/21/2016(UTC), N5VR on 2/22/2016(UTC), KE2YC on 2/24/2016(UTC)
#103 Posted : Tuesday, March 1, 2016 9:40:10 PM(UTC)
March 1, 2016
9.0.84
  • Fixes errors with prefix lookup when entering invalid callsigns of this format: ZA/1.
  • Fixes errors with prefix lookup when having entered duplicate callsign exceptions in the prefix table.
LOGic9Update84.exe (40,782kb) downloaded 1,146 time(s).
5 users thanked WN4AZY for this useful post.
KA1J on 3/1/2016(UTC), w2zi on 3/2/2016(UTC), W5GA on 3/2/2016(UTC), W4MMR on 3/4/2016(UTC), KE2YC on 3/13/2016(UTC)
#104 Posted : Monday, May 2, 2016 8:59:48 AM(UTC)
May 4, 2016
9.0.86
  • Overhaul to radio interfaces. The polling/no polling option on Icom/Kenwood/Elecraft has been redone to eliminate or reduce errors on the display. The data received interrupts now run on a separate thread.
    The K3 interface in particular should be a lot better. Many thanks to WA4PGM and his hospitality and use of his K3 for this. I have made some changes since I was with Kyle, so if there is any problem, I will be watching the forum today and tomorrow and can fix any errors that occur. If you need to roll back to .84, simply installing the .84 update should put you back where you were.
    Try polling and not polling.
    I fixed an error on the OmniRig interface -- variable OLD_CurVFO not found.
  • DX Summit support is back. It is no longer browser-dependent.
    Do not set the Interval too long. The new default is 1 minute, and I have been running 0.3 minutes here. It will always download 25 spots initially, then fewer at subsequent intervals. If it downloads 25 spots after the initial download, please decrease the Interval.
LOGic9Update86.exe (40,793kb) downloaded 846 time(s).
8 users thanked WN4AZY for this useful post.
KA1J on 5/2/2016(UTC), K1VC on 5/2/2016(UTC), K8ZM on 5/3/2016(UTC), N5XZ on 5/4/2016(UTC), wa4pgm on 5/4/2016(UTC), 4x1ru on 5/5/2016(UTC), W5GA on 5/11/2016(UTC), OZ4CG on 5/17/2016(UTC)
#105 Posted : Friday, June 10, 2016 12:35:05 PM(UTC)
June 10, 2016
9.0.87
Fixes errors in contest logging and scoring.
LOGic9Update87.exe (40,843kb) downloaded 723 time(s).
KA1J on 6/10/2016(UTC), K1VC on 6/11/2016(UTC), W5GA on 6/12/2016(UTC), KE2YC on 7/1/2016(UTC), LU1BJW on 8/6/2016(UTC)
#106 Posted : Tuesday, July 5, 2016 3:35:56 PM(UTC)
9.0.89
Fixes reading split freq in Kenwood/K3. Not tested.
LOGic9Update89.exe (40,794kb) downloaded 1,039 time(s).
KA1J on 7/6/2016(UTC), K1VC on 7/7/2016(UTC), N5XZ on 7/7/2016(UTC), OZ4CG on 7/16/2016(UTC), KE2YC on 8/7/2016(UTC)
#107 Posted : Tuesday, August 16, 2016 4:52:07 PM(UTC)
9.1.1 September 5, 2016
All future LOGic updates will be handled by PDA's update server. To get the latest update, install this, then click Help/Check for updates.
This update adds built-in updating. After installing this, Click Help/Check for Updates. Go ahead, try it! This will get you a list of available updates. You may download the latest update if you have purchased LOGic within the past year, or your update subscription is current.
To renew your update subscription, click here.
Click here to download.
Also, after installing the above, download and install this update to the updater.
vk4iu on 8/16/2016(UTC), w2zi on 8/18/2016(UTC), AA3EJ on 8/19/2016(UTC), K1VC on 8/22/2016(UTC), KA1J on 8/22/2016(UTC), W5GA on 8/27/2016(UTC), KE2YC on 9/11/2016(UTC), wa8qyj on 12/1/2017(UTC)
3 Pages<123
This page was generated in 0.080 seconds.
