Rotor control crashes LOGic (but only sometimes)
#1 Posted : Sunday, July 17, 2016 6:00:56 PM(UTC)
A new issue with LOGic.
[Sometimes] when I click on the rotor control, it crashes LOGic. The screen grays out and I get: LOGic.exe ahs stopped working. Windows is checking for a solution to the problem..."
See attached.
#2 Posted : Monday, July 18, 2016 8:51:15 AM(UTC)
What rotor and driver are you using? I gather it just became a problem with no changes?
There is probably additional information in the Windows event viewer. In win 10, search for Event Viewer. Run it. Select Windows Logs, then Application.
#3 Posted : Monday, July 18, 2016 9:41:53 PM(UTC)
I am using a Green Heron RT-20 via the serial port and the Hygain DCU1, Green Heron driver.
COM5
Default baud rate
2 stop bits
Poll is checked
Nothing has changed on my side, but I only recently started using the on-screen rotor control.
I am using an old Prolific cable, but I know it is a genuine one because I bought it from Elecraft before they changed to FTDI.
Still using WIN7, 64 bit.
#4 Posted : Tuesday, July 19, 2016 11:24:56 AM(UTC)
Prolific has always been problematic. Try turning off Polling, and also try the legacy interface.
Using LOGic's graphical rotor controller would cause the rotor to be polled, so that is a possible explanation as to why it quit working all of a sudden.
Let us know.
#5 Posted : Tuesday, July 19, 2016 11:48:23 AM(UTC)
I will try that later.
I forgot to mention that setting the rotor direction from the Spot Log NEVER crashes. It is only the Rotor Control window. I think that probably eliminates the possibility that it is the interface cable.
#7 Posted : Wednesday, July 20, 2016 8:46:54 AM(UTC)
I turned off "polling" in the rotor setup and so far no crashes with the graphical rotor control.
