Posts: 11 Location: Arizona
I have logic 9 working on my new computer. I downloaded and ran the latest Logic9 update LOGIC9UPDATE60.exe including the latest prefix table and ran all. Things look pretty good but there is one problem for sure. Whenever I run a DXCC Awards Progress List Report the report says that there are 341 active DXCC countries. I am pretty sure that the latest count is 340. What did I miss in this installation? Thanks, Joe W6RLL
Hi Joe,
You are right. There are only 340 active countries that count. I strongly suspect the problem is MVI (the island between Finland and Estonia). It was deleted a few years ago. You will have to do a web search to find the date it was deleted.
You will then go to Tools, Setup, Prefix Table and change it to deleted and put in the date. By using the date it was deleted you will still get credit for it in your deleted countries count. Don't just delete the prefix!
Good luck,
Bill W7OO
Thanks for the help. I have it working as it should now. I used the List of Valid Values, DXCC and deleted 4J1. Thanks again de Joe.
Deleted DXCC's should be left in the lists table, but with DELETED checkmarked. Just install this DXCC list and you are good: http://hosenose.com/Foru...e-updates.aspx#post2105
Tnx & 73, Dennis WN4AZY
