Latest LOGic 8 maintenance update
#1 Posted : Tuesday, June 7, 2011 12:44:20 PM(UTC)
Below, you can download the latest LOGic 8 update.
Important note: Check your current version of LOGic by clicking Help/About. If it is version 8.0.97 or earlier, you must perform the following steps before installing the update:
Delete the file CALLBOOKS.DBF from the LOGic8\LogData folder. DO NOT delete CALLBOOK.DBF! Delete only CALLBOOKS.DBF (plural). (If you delete the wrong file, reinstall your original CD-ROM on top of your current installation -- do not uninstall first. This will recover the missing file.)
WA9ZOH on 10/12/2011(UTC), w4jcm on 4/3/2012(UTC)
#2 Posted : Tuesday, June 7, 2011 12:46:48 PM(UTC)
Click Show to see changes to prior versions:
8.0.104 (Feb 16, 2011)
  • Fixed bug "field xxxx not found" errors while filtering
logic8update104.exe (6,035kb) downloaded 1,464 time(s).
#3 Posted : Sunday, October 14, 2012 1:50:13 PM(UTC)
Fix to accomodate change in QRZ subscription servers.
This is the last update to LOGic 8, folks. LOGic 9 has been out almost a year now.
logic8update105.exe (5,924kb) downloaded 977 time(s).
ei8ht on 12/6/2012(UTC)
#4 Posted : Sunday, October 14, 2012 7:16:10 PM(UTC)
If you get an error "Variable GUID not found" or QRZ subscription does not work, please download and install the update again. I apologize for the inconvenience.
This page was generated in 0.236 seconds.
