LOGic Forum
LOGic Support
eQSL
eQSL Picture Download Problem - Microsoft Visual Pro Error "src = tag not found..."
Posts: 10 Location: Stow, OH
Thanks: 1 times Was thanked: 1 time(s) in 1 post(s)
In the last month I have been getting an error message from eQSL saying that it cannot download photos. I have confirmed that I am logged into site and even see the QSL displayed,but I get a long error message starting with- "src = tag not found...." (see attached screenshot for ful[img]null[/img]l message)
Groups: Administrators, Beta Testers Posts: 835  Location: Auburn, GA Thanks: 18 times Was thanked: 69 time(s) in 63 post(s)
Yeah, they totally changed things around up there. The pictures are .PNGs instead of .JPGs too. GDI+ and I think Foxpro both support .PNG, so we should be able to accomodate it. Stay tuned!
Got the code here to work. Look for an update in a few days.
Posts: 19 Location: Piqua, OH
I am still getting the "src" error message. At least in my case update 43 did not solve the issue.
Ok, not seeing any problems here, and others have confirmed that it works.
Click Help/About and make sure the update really installed.
Then attach a screen shot of the error message display.
Help/About shows update was installed. eQSL confirmation downloads, but not picture. Don't know how to attach screenshot in Quick Reply. Will send via email to your attention.
Thanks & 73,
Tom
Thanks for the email regarding this. Looks like they are now sending either JPG or PNG.
Have you been able to figure out why I continue to get the "src" error message? Downloaded QSO's from eQSL are properly recorded in the "eQSL Received" field of the log, but no eQSL QSL Cards are downloaded to "Pictures". I have tried both the .jpg and .png settings in the eQSL Defaults, but they make no difference.
Tom W8POF
You are getting the error because LOGic is expecting .PNG and eQSL is sending .JPG.
I was not aware that there was a setting for this. No matter, I will set LOGic up to handle either. Please sit tight.
Thanks Dennis. Login to eQSL. Setting is under "My Profile" "Advanced Features". There is a box that can be checked to "Display all eQSLs in JPG format instead of PNG".
Will sit tight. Thanks & 73,
Tom W8POF
1 user thanked W8POF for this useful post.
For everyone's info, this was fixed in the .44 update.
Posts: 4 Location: Denmark
Hi Dennis! During some time I have not been able to download the pictures from eQSL. No error-message... I am using LOGic8 with great pleasure, but this problem would be nice to have solved. Do you know how and when this will be solved? Or do I have to convert to LOGic9.. ? (A big job to start all over with all my personal settings from LOGic8...) Vy 73 Carsten OZ4CG
Hi Karsten: They changed eQSL.COM and we are still working out problems some users have on LOGic 9. We are not going to fix this in LOGic 8. Sorry. Moving the settings across is not difficult. http://hosenose.com/Foru...wnloadable-LOGic-9.aspx
Try the setting recommended by W8POF to make it always download .JPG files. That could well fix it. Tnx & 73, Dennis WN4AZY
Thank you Dennis! I will live with it, since I have a lot of trouble to get LOGic9 to work properly, and since my customized LOGic8 is doing very well most of the time. (But some day I guess, I will have to spend the nessessary time to find out.....) Thank you for your answer. Vy 73 Carsten OZ4CG
LOGic Forum
LOGic Support
eQSL
