LOGic Forum
LOGic Support
Report Writer
DYMO QSO LABEL TYPE SIZE TOO SMALL
Posts: 85 Location: Syracuse, Utah Thanks: 21 times Was thanked: 13 time(s) in 12 post(s)
Can someone help me resize an existing QSL label or create from scratch a new one? I have a Dymo LabelWriter 450. I've been using the Dymo Label #30252 (1 1/8 x 3 1/2 inch). I've received several complaints about how small the print is on this label. I've been using the QSO report that is provided with LOGic 10 (DYMO QSO LABEL). I would like to go to Dymo Label #30256 (2 5/16 x 4 inch). I have been able to make some limitd changes to the DYMO QSL LABEL report format provided, but the type face remains very small. I've attempted to increase font, but I cannot increase the size sufficiently without having problems such as the year printing out as 3 stars.
The folks at the ARRL outgoing bureau have suggested 12 point type as a minimum.
I've tried to figure out how to increase the DYMO QSO LABEL size to match the larger label #30256, but have been unable to figure out how to do that. That would be the easiest thing for me to do. From there I know how to move the things around and change the font size.
If that is not possible, I would like to create a new report specifically for the larger Dymo Label #30256. I would also like to be able to report more than 3 QSOs per label. Even at 12 point font I think it would handle five QSOs. I like the DYMO QSL LABEL format but I am not tied to it.
Groups: Administrators, Beta Testers Posts: 3,057 Location: Auburn, GA Thanks: 969 times Was thanked: 484 time(s) in 399 post(s)
Hi-- Here is how to change the form size: https://www.hosenose.com...port-modifications.aspx
Just change the size of the detail band. The font IS small -- 8 point. This label supports up to three QSOs per label, so there isn't a lot of room to go bigger. You COULD make it 2 QSOs. Then you could probably go with 10 pt. Let me know if any questions. Tnx/73. DH
LOGic Forum
LOGic Support
Report Writer
