LOGic Forum
LOGic Updates
LOGic 9 Updates
Logic 9 on separate (backup) computer
Posts: 63  Location: Winthop, WA Thanks: 5 times Was thanked: 9 time(s) in 9 post(s)
Dennis, I would like to use Logic 9 on a separate laptop as a backup to my main computer. I find I can't update the backup computer because it shows my subscription has run out. I still have until December on my main computer. How can I use a second computer with the same subscription as my main computer? Thanks and 73, Ron
Posts: 180  Location: Daytona Beach, Florida Thanks: 48 times Was thanked: 67 time(s) in 62 post(s)
On the main machine, from the start menu, run the LOGic Updater. Check the box to "Retain file after installation." Quit when it actually starts the install. Copy that EXE (usually saved on the desktop) over to the new machine. Run it. LOGic should all run and have your info. Quit and then copy over your data.
73s, Don W2ZI
Don, thank you for the hint. However when I attempted to run the update on my backup, Login came up saying my subscription had expired last year and would not load the program.
I will have to contact Dennis directly, I suppose.
Thank you for the help,
Ron
Groups: Administrators, Beta Testers Posts: 3,257  Location: Auburn, GA Thanks: 1135 times Was thanked: 554 time(s) in 464 post(s)
Hi Ron:
Copy your LOGic license file from your new setup to your old. It is named LOGIC.LICENSE and is located in the LOGic install folder, which is typically c:\program files (x86)\LOGic.
Or, install your last update subscription on the backup computer.
Tnx for using LOGic.
LOGic Forum
LOGic Updates
LOGic 9 Updates
